Female pin connectors
A place for the physical connections
cpunches
Post by cpunches » Wed May 01, 2013 10:19 am
Can anyone give me the specs on the connector pins that come in the Rambo kit? I managed to use all of them up during my build and I still have a couple of connections that I'd like to redo. I ordered some from Jameco but they were the wrong size and won't fit the 4-pin connectors that plug into the Rambo.
ULTIMATE 3D JEDDI
Re: Female pin connectors
Post by Jimustanguitar » Wed May 01, 2013 10:51 am
I bought some from Ultimachine for the same reason. They came in a Farnell bag with the numbers on it, so I'll check it tonight and post it for you.
ULTIMATE 3D JEDDI
Post by Eaglezsoar » Wed May 01, 2013 11:40 am
http://www.mouser.com/ProductDetail/Mol ... Dr7T8xxg== Housings
http://www.mouser.com/ProductDetail/Mol ... uX%2foQ%3d Pins
http://www.mouser.com/Molex/Headers-Wir ... loZ1yzvh3j Everything
The above links are for the housings and pins you need.
The last link is in case you want to see the whole series.
cpunches
Post by cpunches » Wed May 01, 2013 1:21 pm
Thank you both.
Return to “Nuts and Bolts”
