What is in your tool chest?
A place for the physical connections
wepollock
Postby wepollock » Sat Mar 24, 2018 1:44 pm
The crimping tools I am using have allot to be desired. I was looking at Molex tools and no thank you, I am not buying a multi hundred dollar crimping tool. I just purchased an "Engineer PA-09"; what are you using..
PS I am interested in the "best of" tools others are using.
ULTIMATE 3D JEDDI
Re: What is in your tool chest?
Postby Xenocrates » Tue Mar 27, 2018 10:30 am
I use Tri-crimps from Powerwerx for most different crimp connectors, since they are comfortable and reasonably cheap (And most of the other tools aren't meant to crimp power poles, so I'll take it and the interchangeable anvils). For the .1" pitch connectors, I use the cheap ones from Hansen Hobbies, and I've not had too bad of luck with it, having crimped enough to assemble two+ printers (Original connectors, then adapters from those to Duet, so nearly enough for 3).
As for a best of, I'm very fond of the Wera maintence screwdriver sets. For around 65$, you get insulated screwdrivers with nice handles, making it slightly less likely for you to do something like short the heater voltage while tightening the terminals if you're crazy or forgetful and are playing around in the electronics bay live.
Rostock Max V2, 760W corsair modular PSU, PT100 enabled E3D V6 and volcano, self adjusting carriages, Raymond style enclosure
forrie
Postby forrie » Wed May 30, 2018 4:10 am
I also have the Engineer PA-09. They work really nice....
ULTIMATE 3D JEDDI
Postby Mac The Knife » Wed May 30, 2018 7:26 am
I bought the IWISS 28B, Ratcheting crimpers off of Amazon. They work really well. http://a.co/jiewv7g
Return to “Nuts and Bolts”
Who is online
