Page 1 of 2
SIMPLE CONNECTOR FOR HOTEND WIRING COMING SOON
Posted: Fri Apr 07, 2017 10:01 pm
by Jassper
In the beginning.....
There was a rats nest of wires, twisted, soldered and tapped.
Then came the Yellow Jacket Quick change hot-end plate.... and it was good.
Then came Trick Laser, E3D, and 713Maker presenting a multitude of choices for the user.... and it was good
Now, in the ultimate engineering trifecta with Trick Laser, Yellow Jacket Concepts, and The Makerhive come together to bring you the next revolutionary break through in hot-end assembly - The Quick Clip.
* No soldering
* No pin crimping
* 100% compatible with Rostock Max v3 harness wiring.
* 100% compatible with the Stock SeeMeCNC platform and arms.
* On board micro switch to manually turn off part light ring.
* Allows you to quickly swap hot-ends
* Allows for quick repairs with nothing more than a jewelers screwdriver. replace the Thermistor, the Heat cartridge, or a fan within minutes.
Top connection is an 8 pin pluggable connector compatible with the Max v3 wiring. A Hot-End, peek fan and Part fan LED. There is also a 2nd connection that breaks out the 3 wires from the Harness if not using the accelerometer board, use this connection for a prob switch or your own accelerometer. Connections on the bottom is a Spring cage connection similar to the 8 pin plug, no soldering, no pin crimping. It provides connections for a part LED light ring, The Thermistor, Hot-End, a Peek fan and 3 connections for part fans.
The Quick Clip coming soon ... and it is good.
Re: SIMPLE CONNECTOR FOR HOTEND WIRING COMING SOON
Posted: Sat Apr 08, 2017 1:11 am
by Glacian22
Yes plz. :D
Posted: Sat Apr 08, 2017 10:37 am
by AlanZ
Sign me up!
Posted: Mon Apr 10, 2017 12:09 pm
by djarmag
I was brainstorming for the longest time trying to think of how I was going to quick swap hotend setups with the accelerometer board with 713maker mount while trying to access the Bowden fitting to secure it. This takes care of both clean and Bowden access.
TAKE MY MONEY!
Posted: Wed Apr 12, 2017 2:09 pm
by Jassper
Good to here! They should be available in about 2 weeks.
If interested, shoot me a PM and I will create a pre-oder so they ship as soon as they are ready!
Posted: Sat Apr 15, 2017 12:53 am
by Jassper
Here is a PDF showing the pin outs.
http://www.themakerhive.com/files/YJ-QC/Pin-Out.pdf
Posted: Sat Apr 15, 2017 8:26 am
by TwoTone
It looks really nice and I was planning on getting one, but it needs one more pair for me.
We need all the connections it currently has plus one for a IR probe.
Posted: Sat Apr 15, 2017 9:02 am
by KAS
TwoTone wrote:It looks really nice and I was planning on getting one, but it needs one more pair for me.
Mentioned above in the text (There is also a 2nd connection that breaks out the 3 wires from the Harness if not using the accelerometer board, use this connection for a prob switch or your own accelerometer.)
Unless you're looking to use the accelerometer and another probe at the same time?
Posted: Sat Apr 15, 2017 9:25 pm
by TwoTone
yea I see it now, I was rushing when I looked at the pin out picture and thought the way the bottom was split matched the top.
Posted: Sun Apr 16, 2017 2:19 pm
by DeltaCon
KAS wrote:Unless you're looking to use the accelerometer and another probe at the same time?
At the same time seems improbable, but on different hotends you want to be able to swap out that does not seem improbable at all.
Posted: Mon Apr 17, 2017 11:11 am
by Jassper
Yep, if your not using the HE280 accelerometer board, you can use those extra 3 for what ever you want.
Posted: Mon Apr 17, 2017 6:28 pm
by Jassper
Posted: Mon Apr 17, 2017 8:16 pm
by AlanZ
Order placed. Thanks Jasper.
Posted: Mon Apr 17, 2017 9:59 pm
by TwoTone
I ordered one.
How about offering the connector for the 3 pin as well to make it simpler.
Posted: Mon Apr 17, 2017 11:08 pm
by Jassper
TwoTone wrote:I ordered one.
Thanks for mentioning that! I'll have to update the description. The 3 pin connector comes with it. :D
The reason the 8 pin connector does not is because if you have a V3, you already have the correct connector - although it may not be the locking one. Just makes it a little cheaper for those that don't need it. I wouldn't expect people to have the 3pin one, so I include that with the board.
Posted: Thu Apr 27, 2017 3:56 pm
by Jassper
The Boards have arrived, so I should be on schedule for shipping Monday May 1st!
Posted: Mon May 01, 2017 12:04 pm
by bvandiepenbos
Got a board this past Thursday at the MakerHive.
Install was super easy... the neatest and quickest EVER! Sure is nice to not have to crimp pins or solder.
Very handy to have direct plug in compatibility with stock SeeMeCNC 8-pin plug wiring harness.
Now I can quickly swap platforms between machines. HE280 on the MAX Metal custom build, E3D platform from MAX Metal on Stock V2/v3 etc. etc.
The little switch to turn off light ring is pretty slick also.
Posted: Wed May 03, 2017 6:41 pm
by Glacian22
Ordered! Time to streamline the mess of connectors, I am super looking forward to getting it installed! :D
Posted: Thu May 04, 2017 8:09 am
by Jassper
Jassper wrote:Here is a PDF showing the pin outs.
Updated pin-out sheet, minor additions.
Posted: Thu May 04, 2017 9:02 am
by TwoTone
Excuse the ignorance on the abbreviations
SCL, SDA, INT?
Posted: Thu May 04, 2017 9:25 am
by Jassper
TwoTone wrote:Excuse the ignorance on the abbreviations
SCL, SDA, INT?
On an I2C bus, you have the Clock line (SCL) and the Data Line (SDA). INT is Initialize.
Those 3 pins are only used on the Probe board from SeeMe, so if you are using your own hotend without the probe board, those 3 pins are open.
Posted: Thu May 04, 2017 9:55 am
by Eric
SCL, SDA, INT?
Close. You swung and missed on INT, but got the rest of it right.
INT is a line from an interrupt pin on the accelerometer that's used as an dedicated output signal to indicate a probe hit. So not Initialize, but Interrupt. It has nothing to do with the I2C bus.
SCL = Serial Clock Line. SDA = Serial Data Line. These are the only two data lines associated with the I2C interface. Also known as TWI (two-wire interface). Technically a third wire (a common ground between devices) is also required for it to work.
Posted: Thu May 04, 2017 10:42 am
by Jassper
Eric wrote:
SCL, SDA, INT?
You say tomato I say tamoto... :D
Thanks for the clarification. I've never use i2C so not familiar with it myself - was shooting from the hip.
Posted: Mon May 08, 2017 6:45 pm
by AlanZ
I managed to get the new connector hooked up to a E3D-v6.
I struggled getting the wires into the holes without deforming the wires (especially 26 gauge wires) against the internal springs. I tried activating the spring release while inserting, but that was too much of a juggling act.
So I tinned the wires with a little solder and then the assembly was very quick and smooth.
Posted: Mon May 08, 2017 7:39 pm
by TwoTone
Never put tinned wires in a spring connector.
It really wasn't hard to open the spring release
